whats the smoothest rom for optimus v with long battery life??
Re: whats the smoothest rom for optimus v with long battery life?
This is what I think
1. Resurrected Bumblebee
2. Harmonia 1.87
3. Harmonia 2.+
4. I would say it's a tie between Migage and OM-Mandylion.
5. Backside and Magpie
6. BobzHome
The ICS roms have about the same battery life as stock
Reactions: topdawg661
Probably MiRage
Harmonia 2.09 definitely. :) The ICS roms are still being worked on, so I wouldn't use them as a daily just yet. But if you want the look of ICS, you can always apply a theme!
Harmonia 1.9 for sure! Mirage, G-T-R, and Gingersnap are all up there for sure though!
And I want mms fixed for picture and video sending I have bobzhome and they don't work
MMS works on almost every ROM except for Ice Cream Sandwich.
Mirage link: http://forums.androidcentral.com/op...hacks/179602-rom-kernel-mirage-cm7-2-iho.html
Gingersnap link: http://forums.androidcentral.com/op...p-1-3-5-7-23-12-stock-lg-ui-small-update.html
If you're really looking for maximum battery life, download Battery Defender off the market, and use interactive governor set 122 MHz as minimum and whatever you're max overclock is, I'll just assume 806. And there you go.
MMS works on Quattrimus just fine...pretty sure it works on Bobz ICS as well.
I am loving Gingersnap right now. I've used both Harmonia & Mirage and would rank them in my top 3. I have had the least # of fc's w/ Gingersnap and it is smooth and has great battery life (all 3 are pretty good on battery if you have a good OC setup).
The 7/27 build of ics from Bobz is awesome for battery life, but please don't take my word for it just back up and flash. It only takes a minute to nand back. As for juice defender. Why would some one run another app constantly to try and improve battery life? Seems to defeat the point in my eyes.
And low clock speeds aren't exactly proportioned to battery life as one would think.
annahernandez51
