What's your favorite clear Nexus 6p case?
I got a Redshield branded case from Amazon. Very thin, fits well, and the pushbuttons are very responsive. Just what I was looking for. Probably not very protective, but that wasn't my priority.
I believe all clear cases will yellow over time. All three of mine did, within 6 to 9 months. Just get a cheap one you like and replace it.
How's your Hybrid holding up with scratches on the case, back, side and overall look? Just got one and I'm really impressed as far as first impressions go. Thanks
Appreciate you getting back to me. I guess that's just how it goes w/ the clear cases. At some point they'll yellow no matter which one you get lol
Not sure what colour phone you have but if you got the black one you can't tell if your clear case is yellowing over time. Within reason of course, all cases start looking gnarly eventually if you keep them long enough
True true, I happen to have the gold.
I really liked my Ringke fusion, although it did yellow. It was a sturdy slim case, and have considered buying a replacement since it was only $13 when I bought it. I'm now using the Diztronic Voyeur series. It's even sturdier, added only a micro amount of thickness, but it has been dropped countless times without issue after buying that case and it's saved my bacon each time. My only complaint is that it does not have the clear sides all the way around like the Ringke, which I liked because with my silver back because it made it easy to find the phone no matter which side was up. Of course, those sides are also what yellowed.
Do you like the Ringke or Diztronic better? I use the Spigen Neo Hybrid case everyday & I'm really happy but my headphones don't fit. There are some good suggestions on here. I'm not sure whether to go with one of the two you suggested or maybe the Spigen ultra hybrid or one of the first few suggestions at the top. I do like the clear sides too
redmercer
