When and how to extend memory?
  • Start date Start date
A
AC Question
I have a Galaxy A5 2016. Memory is 75% full, storage 35%. I have very few pics, downloaded apps, no music etc. Almost all the memory/storage is apps which came with the phone and automatic updates. Can I do anything to remove/disable apps, or to extend storage? I can't afford to replace my phone if memory is running out this fast.
You can put an sd card in it.
Most apps aren't happy to be moved to sd card.
If you go to play store, settings and stop auto updates. Any apps you don't use, you can either uninstall or at least disable. Often they will uninstall updates when you do that.
jackgomes0321
