When away from home and using Samsung S6 Edge I am only showing 3g usage not 4. Any help please?
  • Start date Start date
A
AC Question
When away from home and using samsung s6 edge i am only showing 3g usage not 4. Any help please
I exchanged my s3 for s6 edge and transfered sim card. I now only get 3g when using phone away from home or other wifi point. Is it because i swapped sim card or is there a problem with the phone.
Jacky
Re: When away from home and using samsung s6 edge i am only showing 3g usage not 4. Any help please
Jacky
Welcome to Android Central!
Try going in to your settings, mobile networks, network mode, depending on where you are select LTE/WCDMA/GSM (auto connet). That should fix you up if that is the issue.
Vresbudsbenz
