Where do you carry your Note 2?
I'm quite pleased with this combo. Getting the phone into and out of the holster was a bit tight when I first got it, but it is getting a bit easier now. It is still quite snug, so I have no worries about the phone accidentally sliding out. It doesn't add much bulk, at least to me. I like the silicone lip around the front to protect the screen and the harder plastic to protect the corners should I drop the phone. The kick stand on the case works fine, but haven't found a need for the one on the holster as I put the phone screen side in. The case gives me a better grip on the phone. You could also remove the harder plastic part and keep the silicone part on if you needed to slim down the profile for a time, but you'd be losing the extra protection on the corners and the kickstand.
I've not used any Seidio products so I can't draw any comparisons. The Galaxy Note II is the first phone I've bought a case for, as my original Droid Incredible with extended batter didn't fit any of the standard cases.
Ya a case is need to help with the grip of the phone. It is too slippery without a case in my opinion.
I purchased a Otter Box defender for mine and use the belt clip. I thought it would be to big to carry but was happy to find that it is very comfortable.
Sent from my SPH-L900 using Android Central Forums
Does the screen protector that is part of the case interfere with the S pen?
Sent from my SCH-I605 using Android Central Forums
No. It actually is very smooth and transfers just as it does when writing directly on the screen..
I actually asked the same question and only bought it after I tried it.
Sent from my Note 10.1.
I keep mine in a wallet flip case in either my back pocket (like a wallet) or in my coat breast pocket. I usually wear relaxed fit jeans and I'm not a big guy by any means (155lbs. soaking wet) and it doesn't bulge or look unsightly at all.
Sent from my sweet Verizon Galaxy Note 2
You guys are going to go out to the bars and crush your screens when you fall asleep with your huge absurdly expensive phones in your pockets...:D
Sent from my Note 2 using Tapatalk 2
You know, I actually thought this would be an issue. But with the wallet case on it, I have found that it is actually thinner than my usual wallet. And the case actually gives it a great deal of protection and rigidity. I do remember to take it out of my pocket when driving or when I will be sitting for an extended period of time, though. No reason to tempt fate.
I wish I still had time to go out to bars.....:( the only thing I really worry about is getting it wet at work.
I'm happy carrying mine it its holster. I have the phone in a Seidio Active case.
Sent from my Galaxy Note 2.
How do you like that flygrip? I've been thinking about getting one, but don't like that it can only be utilized in lanscape or portrait, not both without reconfiguring the adhesive. I'm talking the holding it in your hand functionality, not the kickstand.
^^ This ^^ I've been using Seidio Cases & Holsters ever since I started using Android which was right around the time the EVO surfaced. I'm currently using a Surface Case Combo so my Note resides on my hip for most of the day
Front left pocket with Body Glove. No other items allowed in that pocket. It's been a month and a half. So far so good.
Did you order from this person? Where is Baldwin Park? How long for delivery?
Sent from my Verizon Note 2.SCH-I605 using Android Central Forums .
I ordered from ebay user "cellcostumes". I just linked to the first one I found that looked like the one I got.
Carpenter jeans, they have a perfect phone pocket that's on the side of your leg. The S3 fit better but the Note 2 still fits just a little tight.
apache dawn
