Where is Smart Network Switch after upgrade to Oreo on Samsung S7 edge?
stacie_j
I have a Samsung S7 edge. I upgraded to Oreo a couple weeks ago and experienced huge problems (as many others have) including horrible battery drain. I cleared the system cache and that helped somewhat. Biggest problem of late is that it seems that Smart Network Switch (SNS) is no longer in any menu. I don't get a "more" option to click when I'm in WiFi settings (which is where it was located before). I just have the option to click WiFi Direct or 3 vertical buttons. After clicking those buttons I can click on advanced settings - but SNS is not there either. I have 3 Alexa devices that I have to reset and none will work unless I turn off SNS, but I can't! Anyone know where it went?
Go to WiFi and then click on Advanced. Uncheck "Switch to Mobile Data" as well as uncheck "Turn on WiFi Automatically" to be on the safe side. That worked for me as I have several Alexa devices myself.
amaka
