Where to buy Nexus 7 speaker assembly??
So just an update if anyone cares... replacing the speaker assembly takes about 2 minutes and, as long as you're careful, there is no way to know the rear cover was removed. It was simple.
Where did you get yours from, I have the same issue. I dont want to send mine in and wait a few weeks with out my tablet, ill go through withdrawls, or worse.
I just called Google, and they are sending me a new device. The I don't have to ship them my device first. I What awesome customer service.
Hey guys, my nexus7 speaker probably blew during playing this new rovio game (damn pigs!! :))
I see some of you have contacted google, how can I do it? I bought the device on a vacation to NY from B&H
Why don't you just replace it under warranty? Your logic makes no sense (to me anyway).
Once you open the case you void your warranty, so if something goes wrong you're out of luck.
He said he he's happy with that device considering the amount of faulty units "out of the box" that's been shipped. Plus the agro of shipping waiting and and gambling if you get one of said faulty units.
I just got mine back from Asus repair today, description says they replace the speaker.
Hi! i have the same problem, where do you buy the speaker replacement?
where to buy nexus 7 charge port flex and cable
Hi
I received a nexus 7 from my friend. I came to realize that it was rooted and installed with cyanogenmod. I was using it for a while and it worked well. Then problem started with charging. White dots and lines appeared on my screen. I tried to do a hard reset with the volume and power buttons. Nothing works. I put it to charge on the wall socket overnight. But the battery could not be fully charged. I then connected to my PC and it charged 100%, Still connected to my PC, I switched on and PC says denote hardware, run installation with disk. I realized that something is wrong. I then decided to take it down to tablet repair store. They told me that the charger port is broken and told me to look for it. So if anyone reading this can help me, I will appreciate. Thanks:)
pratikkumarBB
