Which 6 Pro case are you getting?
eRod,
Which Ghostek case do you have and what did and didn't you like about it. I was thinking of trying out the Exec Magnetic for the 6Pro
This one. Honestly I like it (color, build quality, and protection), but the raised corners and sides makes it seem too wide in my hand. I do not have small hands haha. The back is very flat with this case so it should work for you.
Ghostek COVERT Google Pixel 6 Pro Case Slim Clear with Ultra Thin Design and Non-Slip Grip Supports Wireless Charging Protective Cover Designed for 2021 Google Pixel 6Pro 5G (6.71 inch) (Stormy Smoke) https://www.amazon.com/dp/B095XH1GF...ag=hawk-future-20&ascsubtag=UUacUvbUpU7012370
1. Bellroy
- Best fit/form factor out of all of them. Very TIGHT fight. It's leather and will show wear and tear.
2. Rhinoshield
- Custom options is a plus. Great protection. The fit is good with no movement from phone. If you use a skin, the honeycomb insert will leave imprints on your skin!
3. Crave Dual Guard
- Solid case for protection without being too bulky. Back is textured for grip.
4. Aioria Fabric
- From eBay. Fantastic form factor and fabric is soft. This was a random order. My wife liked it so much, she claimed it. So I ordered a gray one. The plastic case itself is very basic. Nothing inside like the rhinoshield, Bellroy, or Spigen.
5. Ringke Fusion
- Wish they made the Fusion X for the Pixel. Great case. But this is your standard clear case and is sturdy. Plastic back with TPU sides. Great build quality.
6. Ghostek Covert
- Raised corners and sides kind of bug me. Makes it feel wider in hand, but this case has good build quality.
7. Spigen Rugged Armor
- Standard issue TPU case from Spigen. Slim form factor. Not sturdy like the Ringke. I wish they offered more colors.
1. Bellroy
2. Rhinoshield
3. Crave Dual Guard
4. Aioria Fabric
5. Ringke Fusion
6. Ghostek Covert
- Standard issue TPU case from Spigen. Slim form factor. Not Saturday like the Ringke. I wish they offered more colors.
My experience with Bellroy is vastly different than yours. My p6pro rattles around inside my case because the case is so loose. Still waiting to hear back from their customer service after 3 days and a request for me to send pictures and videos (which I sent immediately).
I ordered directly from Bellroy a black case for my Pixel 6 Pro. The fit is perfection!
Mine works with Ghostek Covert. Did you turn it on in settings?
I got the transparent ghostek case and yes, I did turn it on. I placed another phone on top but nothing was happening. To the point where I would check the setting and it would turn off from inactivity. So is it possible that the case is too thick or maybe I have a defective "battery share"? I also have the Caseology case with the same issue.
I'm not sure. I tried it with airpods and lit up saying it was charging. I can try on another phone later
Bellroy emailed me a satisfaction survey. You should get one too. It shouldn't be all that difficult to get a replacement.
Official Google case, ordered along with the phone. I also ordered the Moment case mainly because it works with Apple magsafe charger and I have them few at various places in my house
How do you like the Moment case? Saw one in a review of the 6 Pro and looked great. Trying not to add any more bulk/thickness than necessary to protect the phone from drops
The Moment case is quite good -- not bulky at all. The only slight downside is that the sides aren't textured, so it's slightly less grippy than my Spigen Liquid Air.
Got my Rustek case today! The real wood veneer back looks and feels absolutely awesome. Has the usual lip at the top and bottom of the screen (not the sides), and the camera bump is also protected by a lip. There's nice pebbled texture at the sides that improves grip. The case itself is very slim -- it's good that it doesn't add bulk, but this isn't the case you want if you need rugged protection.
A couple of minor downsides -- the buttons seem to be a bit of an afterthought -- not raised very high, and no special texture for the Power button like on the Spigen, but they still press fine. And you can easily see a plastic seam line running around the entire edge of the case. But those are easy to overlook given how beautiful the back of the case is. Another good reason to pick them is that they're an indie company out of Portland, OR, who handcraft everything (and hand-deliver all orders to the post office via skateboard!). Highly recommended for anyone looking for a case that's out of the ordinary.
*peeks in thread* Welp...just ordered the Ghostek I knew I should have kept scrolling
How is the feel of the power and volume buttons, and how well does it handle the curved screen? I guess the toughest challenge is to protect it while not making the side swipes difficult.
NVK
