P pappy53 Banned Dec 23, 2009 1,616 27 0 May 30, 2014 #21 dankup said: I don't use my phone often. If it gets used for an hour a day of screen time on then that's good. Click to expand... Then you should be fine, as the S3 is a great phone.
dpham00 Moderator Team VP Moderator Apr 23, 2011 30,108 207 63 May 31, 2014 #22 pappy53 said: S3 battery life is terrible. Click to expand... My s3 gets about 3.5-4hrs SOT,similar to my note 3. dpham00, Android Central Moderator Sent from my Verizon Moto G
P pappy53 Banned Dec 23, 2009 1,616 27 0 May 31, 2014 #23 dpham00 said: My s3 gets about 3.5-4hrs SOT,similar to my note 3. dpham00, Android Central Moderator Sent from my Verizon Moto G Click to expand... Maybe my luck is just bad. I had 3 different ones that wouldn't last a day with fairly light use.
