- Apr 29, 2015
- 7
- 0
- 0
I've been going called on my Note Edge since buying it in February. Saying it is a gimmick is just plain uninformed.IMO, that Edge is just a place for the screen to be cracked. Actually cases are an issue.
The Samsung guy recommend the Note 4 over the Edge to me. For me the edge is just a gimmick thing I don't care about.
S6 Edge in Gold is beautiful and powerful.
And if you have the Gear S, you can do all that and more.I have both phones and actually prefer the Edge because of the edge panel. It is not a gimmick and it does has actual functions which are completely different then the Galaxy S6 Edge.
You are writing a note in an app and a call comes in, you answer or decline it from the edge panel without exiting out of the app you are using.
You can control whatever music you are listening to right from the edge panel without exiting out of the app you are currently using.
You can add favorire apps to an edge panel and open them without going to the home screen.
While using the phone for anything, you get app notifications in the edge panel and you can see if it's something you want to read or get to without opening that app right then and there.
There is plenty that the edge panel does and if I had bought the Note Edge first, I would not have bought my Note 4. I love my Note Edge.
And if you have the Gear S, you can do all that and more.![]()
And if you have the Gear S, you can do all that and more. ??????
My post above was supposed to say that I've been going caseless on my Note Edge since buying the phone in February. I don't feel that it is anymore fragile than my Note 4 or any other phone.
I'm not too worried about it. My boss has a Note Edge and he dropped it from his hand onto a hard tiled floor and there was no damage. It landed face down. They are pretty tough.That Edge is unprotected. I would think a drop on that edge and it not protected is asking for a break.
