Which Phone has better battery life? S4 or HTC ONE?
With the same kind of apps and usage, the One out lasts the S4 by some 4-5 hours from what I've found.
Dunno if it's across the board, but IMO HTC gave a bit more though to power management than Samsung did.
plus, ignoring all the benchmark stuff, IRL the One has better performance, snappier and smoother all over with much less lag.
Sent from my HTC One using Mobile Nations mobile app
I love the htc one i mean who doesnt?!! But I will take s4 in terms of battery life coz you can just swap battery for like 10 secs and have a fresh 100% juice again.
Sent from my LG-E980 using AC Forums mobile app
Or in 2 seconds I flip a switch on my mophie juice pack lol ;-)
Sent from my HTC One using Tapatalk 4 Beta
I get decent battery but I use my phone a lot at work.. And am usually streaming for 6+ hours.
Sent from my T-Mobile HTC One using AC Forums.
I am able to last throughout a day or two with moderate gaming on my S4. I may also be on YouTube streaming or listening to music. Really love the awesome battery life the stock battery has.
Sent from my HP Slate 7 using Tapatalk 4 Beta
I see many people responding
"It depends on usage"
Well, it doesn?t, really
(please do read on)
Any reliable comparison should determine battery life for both phones after being used EXACTLY in the same way
That's the key
Anyone using both in exactly the same way?
The S4 natively provides longer battery life and you have the option of augmenting that by swapping in a fresh same or larger capacity battery or using a Mophie case if youn don't mind increasing the form factor of your phone. However, if I were considering both devices the difference in native battery life would not sway me one way or the other as you can always add a Mophie or other external battery if desired. The BLACK HTC One looks really nice. ...as does the S4.
The Order Odonata. There can be only one.
Also depends on your carrier. If you're with Sprint, the data connection and building penetration is VERY bad and will drain your battery. I left Sprint for Verizon when I got my One and the difference is night and day.
Beyond that, I would also recommend the Mophie Juice Pack. I have one and can easily get through 2 days.
If you don't want the bulk, try an external battery.
Had both, they're really about the same. What's notable is that the One's screen was about twice as bright while providing roughly the same battery life.
trixie909
