Which Screen Protector?
I ordered this one: https://www.amazon.com/gp/product/B...ag=hawk-future-20&ascsubtag=UUacUvbUpU6363217 I'm a little skeptical...maybe thinking I'll buy another set to see which I like best.
If you're planning to use a case on your phone as well, then you might have issues with those type of screen protectors. Those are made to be used on phones without a case. I bought one early on last year for my Pixel 2, and when I tried to put the case one, it popped right off. The edges go out too far. I talked with the manufacturer and they confirmed they weren't for use with caes. So if you see any that are called full coverage and have the black areas on the top and bottom, figure they won't work with a case.
You're mostly correct. Peel makes a case that works with that type of protector. They also make a protector like that. The case is super thin and doesn't offer much frontal protection so it's a compromise.
I love the feel of the peel but it's not much better than a skin.
I've had really good luck with the tempered glass protectors. Has anyone had experience with the Spigen "liquid?"
https://www.spigen.com/products/screen-protector-glas-tr-nano-liquid
I was in a Cricket store looking at their plans and the rep in there was raving about this (not this one specifically but whatever liguid protector they were selling). I dunno, I worry about being able to remove it if I want to, will the liquid get into the speaker openings, etc.
I buy the flat glass ones because he will buy the ones with a curved as you can't use any case the case cause the pop off at the edges so unless you're running just a skin on the back of the phone don't buy the curved screen protector it only stays on for a day or two if you waste your 40 bucks
I'm a big fan of Zagg Glass. I ordered one of these the yesterday
Have seen some good reviews on them. Google Store has then "Coming Soon" as does Best Buy. Can also get them from Zagg, who has them in stock for the 3 and the 3XL. $44.99 - they ain't cheap.
ETA - ZAGG order placed 10/13. ZAGG is a cool name and sounds like it belongs on a P3 XL - :cool:
I have liked the Whitestone dome ones but they are expensive. Either way I don't put screen protectors, just use a case and used screen protectors only on few devices just to try out. For now I'm satisfied just with a case and raised lips. Yes overtime scratches eventually show up but I'm fine with it.
I have no choice to put case and screen protector for work otherwise my phone would be damaged . I wish I can go without it.
Yeah I'm kind of 50/50, I'm not strongly against or for it. Nowadays there are pretty good screen protectors but generally I slide towards not putting them. But I definitely understand those who put as well for various valid reasons.
And the other reason I don't buy the insurance plans .
Heyan
