Which Spigen Case?
I'm using the Spigen SLIM ARMOR, Blue Metal Slate with dimpled back. (Matches the back of the stock S5 phone dimple-for-dimple). It's got a hard-rubber TPU inner-layer and a hard-plastic outer layer.
Amazon.com: Spigen? [AIR CUSHION] Samsung Galaxy S5 Case Slim [Armor] [Slim Armor Electric Blue] DOTTED Design Slim Fit Dual Layer Protective Case for Galaxy S5 / Galaxy SV / Galaxy S V (2014) - Electric Blue (SGP10753): Cell Phones & Accessories
Very solid case and works great with a thick Japanese screen protector. Doesn't get caught up underneath it.
I highly recommend it for light, everyday use.
But if you're planning on rock climbing or something crazy, than you might want to go for something like an Otterbox Defender case which is much thicker and can take a tougher beating. More $$$ though.
My case was like $20. The screen protectors are sold separately.
I bought this one too. I am waiting on delivery. Can you take a pic of your phone in the case!? :D
I use the Spigen Neo-hybrid. I love it on my s4 along with a tempered glass screen protector. Perfect combination.
I have the slim armor case in gold. Brilliant case, just Brough same case in blue :)
I got the first one as a temporary while I figure out what I want. It fits great and looks great but is slippery. Buttons and charge port are all easy to access.
There are a lot of rave reviews for the second one but some of the issues people report were enough to keep me away from it.
I picked this one up this week .
Yea it sticks up enough to where the camera would never touch a flat service. Probly sticks up 1-2mm I'm guessing
Sent from my SM-G900V using Tapatalk
I got the Incipio DualPro and it had the lisp on the front (I always place my phone screen down at night) and the little bit for the camera lense to be protected.
I got the Cyan/Gray and it looks okay with the white phone, but I'm sure it would look great with the charcoal gray/black phone. Still love it. And it's tough to get off. Plus there are soft, rubber, sections for the side keys to be pressed easily. And lots of space for the charger. The one review says it's slippery, it's not too slick. But it's not textured for nonslip. I like it.
I've got the tough armor.
while it's very nice, it can be a PITA to open up the usb port door on the bottom.
I might pick up a 2nd spigen case to try them both out.
I opted for Slim Armor Blue in the Slate Blue color, should be here by Tuesday which means I have to be careful until then since the camera lens looks to be easily damaged.
most definitely! i got one too!
- - - Updated - - -
what's the name of this case? reminds me of my speck case.
maryhurst515
