- Dec 4, 2012
- 35,752
- 832
- 113
My question relates to that as well.I found this: https://plus.google.com/+BensonLeung/posts/H4rx1QRDRBe
I guess the question for me is this: there are 3 parts to charging a phone....the phone port, the cable and the wall unit. My understanding is this, the main concern is the cable and wall plug connection. As long as the cable is approved by Benson, plugging a cable into say any other wall charger or PC should not cause any damage. So the question is how did HTC/LG get around the USB C/QC 3.0 restriction?
Edit: this finding does not change my stance about getting this device. I will get it as soon as I can.
Supposedly; "USB Type-C spec doesn’t support proprietary charging technology above 5V."
But, what part of the 10 is Benson having a problem with? I'm an electronics guy who has built and modded power supplies, so if he pointed to the HTC cable, even the terminals on the cable or phone, or some component that fails past 5v (gets too hot, for example), then it would be clear. Until he points out what HTC has done wrong beyond the theoretical spec, then he's just being a stickler for spec and was out of turn to have said what he did. Overbuilding is something extremely common in electronics and has been since the 30's, perhaps before. As long as the manufacturer provides the accessories that comply to their own required spec for operation then there is nothing dangerous or wrong.
I think the last couple thoughts are dead on. Get a certified cable and you should be ok. Thats a non-engineering assumed opinion. I have noticed that the HTC cable being shown on HTC website is USB 2.0. So I would think if we get iOrange we should be fine as the wall wort is set up (tested?) for that pull. I would have to say the phone has been too.
You lost me on the Overbuilding sentence. Not disagreeing with you, just not familiar with the term in this case.
Understandable. I'm trying to think of an example most can relate to as most I know are in music equipment... It would be akin to what is done with many cars these days. Two companies might source the same engine but one does things in order to run it beyond design spec to get more HP, greater efficiency, etc. One could be critical and say that they are running the engine past spec, but there are things being done to compensate and make it possible. HTC says of their charger; "...it comes with built-in protection against overloading, overheating and short-circuiting." So, using a cable that can handle the 9 and 12v (which are lower in amperage) then I am as a loss as to where the problem is. Now, if HTC doesn't note potential issues relation to quick charge, then that will be an area of concern.
AC looked into this: Qualcomm addresses USB Type-C and Quick Charge 3.0 compatibility Qualcomm addresses USB Type-C and Quick Charge 3.0 compatibility | Android Central
Sorry to have hijacked your thread. Did you get the answer you were looking for?So I know there has been some controversy over bad USB C cables so I am looking for a reliable cable to get to use with this phone not only does it need to be reliable but I need a long cable preferably over 6 feet like the 8-10 range but will settle for 6 if I had to.
Any recommendations?
To charge at full quick charge 3.0 speeds do I need usb c to usb a 3.1,3.0, 2.0 or either?
Plain USB C to C charges pretty quick. My Nex5X charges really quick on the stock charger. As for QC 3, (and I'm not taking into account questions raised by Benson) you would need the proper wall plug, and approved cable. The setup shown by HTC seems to be a USB A to C.
As for any other cable....I would use caution. You needed a longer reach correct? Perhaps there is a different way to achieve what you want? Perhaps with an extension cord?
Your 5x charges quick with that setup because it supports the USB Power Delivery spec.
Speaking of that (and maybe I missed it) does the 10 support that AND QC3.0?
I was under the impression that the benefits of USB v.3.0/3.1 was not only faster data speeds in transfers from one device to another, but faster charging as well. I may be mistaken too.
