Which wireless charger are you using?
Here are pics of my 10W wireless Chargers. Spigen and Anker. Both works well... Except for the static the Spigen causes...
Currently using the 2018 9w Samsung branded charger with no issues. (have UB Pro case on my Note 10+)
Cheers,
BR
I have the new 15 watt at work and then I have a few of last year's wireless fast chargers around the house. The 15 watt is nice, but it's overkill if you are just using it overnight. The regular wireless charger or last year's fast wireless charger would do just fine.
I have 3 of the Samsung fast wireless chargers that came out with the S7/Note7 line, and the 1 convertible Samsung fast wireless charger that came out with the S8/Note8. and to be honest, I have not used any of them yet. the phone battery lasts me long enough and the phone chargers so fast on the wired charger, that I haven't needed to leave my phone on the wireless chargers at all. I used to use my wireless chargers to top off when I needed it, or to charge my Note7/S7E/Note8 over night, but I haven't needed to do that with my Note10+.
Honestly for me, the battery life has been that good paired with the really fast wired charging, that I dont know if I'll need my wireless chargers.
I use an old TechMatte wireless charger pad that I used to charge my old Note 4. It is on the nightstand next to my bed. It uses the Qi wireless charging standard and is not very fast. Then again, I am sleeping so why do I need a faster charger? Once when my Note 10+ was down to about 15% charge left I put it on this charger and saw that it would take a little over 3.5 hours to charge. Since I normally sleep longer than that it did not matter.
I use a ZeeHoo 10W wireless fast charger stand in my car when taking a long trip. That charger along with a Quick charge 3.0 charger in my cigarette lighter will charge my Note 10+ after a long day at a client on the ride home while using the phone. Best thing about this stand is that it mounts multiple ways and I can see/use Navi when I need to.
I've had this one in silver at work for a few years, no need to really change it, because I can pretty much set it on there during my work day if needed (hasn't been needed yet).
https://forums.androidcentral.com/e...ack-sapphire-ep-ng930tbugus%2F&token=2LU5FS8X
I'm using this one to charge overnight so I can also use my phone as a clock at night (and my alarm clock).
https://forums.androidcentral.com/e...tible--black-ep-pg950tbegus%2F&token=YwLJk8WG
Both suit me currently and see no need to upgrade either of them. If I really need a fast top off, I just use wired charging. Also have a fast charger from my Note 8 from Verizon in the car. And my commute is 45 minutes to an hour.
I am using a NOVETE Fast Wireless Charger with Cooling Fan 10w, bought it for use with my Note 9.
From Amazon UK, I'm still happy with it.
I prefer not to abuse my port
What you do on your own time, is your business, LOL.
I was the same way with my Note8. I only pplugged it in to top off if I needed to while I was in the car. At home, and at work, I would use the wireless chargers. But right now, plugging in once a day or 30hrs isn't abuse. At least not to me. I noticed my one wireless charger is at a slow pace and it said 3+ hrs till full. I don't mind leaving it there if I can take it off as soon as it hits 100%, but I sleep more than 3hrs on most nights. maybe 4hrs on a busy weekend. I also don't want to get into the habit of just dropping it on the charger/pad just because it's there.
I'm sure later down the road, maybe in a year from now, I'll be using the wireless charger a lot more, but right now, I don't need to charge as often as I used to with my Note8 and Note7/S7E.
why? mine shuts off when full. it's a great phone cradle. used for my Note 8 and using it now.
Mine doesn't shut off. They keep a slow charge to keep it at 100% until its removed. Am I missing something that makes the wireless chargers stop charging even when the devices are still on them? Maybe I'm misunderstanding how they work.
Mine dont shut off. They keep a slow charge to keep it at 100% until its removed. Am I missing something that makes the wireless chargers stop charging even when the devices are still on them? Maybe I'm misunderstanding how they work.
Mine charges to 100, then over time it'll discharge to 98, then charge back to 100. It'll cycle through that until I take it off. It's to keep the battery from getting too hot and overloading.
mine only charges if it falls below 100%. I kept my Note 8 on it for two years unless I left the house with zero battery damage or deterioration. it's in my home office on my desk. I never even took it to my bedroom so I could sleep without being disturbed.
jenleasch12683
