Whitestone Dome - More curing light or less?
I UV lighted the one on my Note 20 Ultra like crazy and it was still able to peel up pretty easy 5-6 months later.
I don't believe the LOCA ever really hardens.
Have a few extra bottles from past installs, maybe I'll dump some out, UV light it to death and see what happens. :-\
I've been using dome since s8+ and pretty much same steps I've mentioned and never had the waves under the display after curing , that to me sounds like a bad install.
Between my S9+, S10+, S20 Ultra, S21 Ultra I've probably done six or seven total installs. Have done more curing on some and the recommended curing on others. Sounds like everyone's experience is a bit different.
Yeah exactly, one thing I do thats not mentioned is leave it sit almost 24 hours after I cured it with the light , no case and put it in the box it came with and really haven't had issues with that way , I know that method not easy as I have multiple phone to do this .
Good point , I have some extras also , might mess around with it myself .
I suspect that the glue will cure until it's stable, and then can't cure any more. If you under-cure, it will still cure to stability from the UV in sunlight.
Good call, yes. I typically do mine around 9 PM and let it sit until 9 AM the next day before putting a case on it.
Haven't tried the new WSD it comes with new tray and I think glass , have you?
Yes, I have. The S21 Ultra Whitestone Dome kit came with the E-Jig. I find it to be more efficient. Particularly with just being able to drop the glass in and it is stabilized by the sides of the E-Jig contraption. Would definitely say it is an improvement to the process.
I'll definitely give it a try my next Samsung phone
Just put this on my Ultra. Fingerprint scanner never recognizes my fingerprint even after deleting them and redoing them several times. Without the protector, the scanner works flawlessly. Anyone have the same issues?
Have you enable touch sensitivity?
I only did a little extra curing light on this one and everything including the FPS has been working perfect.
I didn't even need to reregister my prints or turn on touch sensitivity.
Had nothing but trouble with my WSD Note 20 Ultra glass.
rose1988
