Whitestone Dome on Note 9
I installed my first one today. honestly there's nothing to it. spend the money take your time and you won't regret the purchase
I almost bought this but had a coupon for the caseology glass protector. It is super simple and so far is awesome! If it doesn't hold up I will attempt the whitestone. Thanks for sharing your experience.
The caseology one causes major touch sensitivity issues. Almost unbearable.
Anyone try the Zagg one yet? Is it full adhesive or only on the sides again? I picked up an Armor Edge one from work and it's side adhesive only grrrr
Whitestone is the best screen protector for the curve with the adhesive it does well. Watch the video though my wife's s9+ was the Guinea pig. I had a couple of air bubbles that I couldn't get out and the more I tried the more adhesive I moved from under the glass which makes a mess. Put one on the 9 as soon as it came out the box no bubbles went on perfect no touch sensitivity.
.....See practice makes perfect.
I also just installed this tonight. I feel like after doing it, the best advice I can give is, get the 2 pack and accept the first one is practice. Even with videos I didn't respect how level my surface needed to be and ended up with a few bubbles I couldn't fix with out risking the (resin? glue? liquid magic? w/e it is, it reeks), so I tossed the first one, cleaned everything back up, and went in for round 2, which was much faster, easier, and went perfectly. Post install I think this is the best screen protector I have ever seen, and I am pretty sure I am now ruined on any other screen protector going forward.
I put mine on last night. Learned a couple things, like make sure you're working on a level surface :P. Once I applied the adhesive I realized the table was on a tilt so I had to hold the frame up at an angle to keep the adhesive from running off the side of the phone. I also had a couple air bubbles but was seemingly able to work them out of the glass before I cured it. I don't see any air bubbles now.
Looks pretty good for the first time doing it and having a couple issues. The only spots that look like they may be lacking some adhesive is behind some small areas of the curves, but I really don't think that's going to be an issue unless I stuck something in there and tried prying, which I am obviously not going to do.
It also fits fine in the Spigen Tough Armor. So far I like it!
Installed this screen protector on my wife's Note 9 I don't use screen protectors personally, went on well but noticed it is shows finger prints big time. You can see every little touch way worse than on mine which has no screen protector. That's the first thing she noticed about it this morning when she said the screen gets dirty easy now. It's really annoying and most likely will take it off and trash it. sucks cause these screen protectors are not cheap..
I have noticed the same thing with the Caseology one as well
THIS! Noticed massive amounts of missed taps within the first few minutes. Left it on for a day cause i had nothing else till my whitestone gets here tomorrow. The small gap the caseolegy protector leaves between the screen and protector makes it unusable.
Great I have a caseology one coming as well. Any other options besides the Whitestone one? Thanks
I wonder if they were not all created equal as I have had no mistaps and the S-pen works flawlessly. I cannot perceive a gap under mine at all. It IS a fingerprint magnet though. I usually go raw dog but the price was undeniable.
How easy is it to get the adhesive off. Just thinking ahead for Note 10 trade in.
Thanks for the tip. Forgot all about the touch sensitivity setting since I didn't use a screen protector on my s9+. Responsiveness is much better now.
Turn the sensitivity up in settings. I have no issues what so ever. You will need to do this with any glass protector.
Don't know from personal experience but what I've read is that it doesn't really leave any adhesive behind once you pop the protector off.
It's surprisingly easy. In fact, most of the adhesive (if not all of it) sticks to the tempered glass and not the phone when you separate the two. I was surprised how clean the removal process was the first time I did it. No issues at all.
Does this dull the display? I got a cheap protector on Amazon. It's nicely adhered despite edge adhesive only and is working well enough, but it has dulled the screen noticeably. I'm not feeling like I'll keep this on long as a result, but I'm hesitant to pay more if it does the same thing.
Ashok Dharshan
