Whitestone Dome
Piece of cake put Whitestone Dome glass a week ago and compatible with all UAG cases. Here's one with the UAG Monarch Case.
Plus has the camera Dome Glass on it as well. Was in a hurry took it with my Note10 Plus.
Edited: Almost forgot the finger print is so fast with the Whitestone Dome Glass i barely have to press the screen to unlock it.
This is the one of the exact reasons I want to send back my Note 20 Ultra. I hate trying to get a screen protector on and I am too worries to go naked. Reason why I love my Note 10+. Its included screen protector is perfectly centered and no dust underneath
If you're were ok with the plastic one that came on the note 10 then check out the LK protectors on Amazon. Closest thing to the stock Samsung ones you can get and SUPER easy to install....12.99 for a 3 pack.
Ive used whtiestone screen protector for my Note10+, and It was cracked when it delivered
Ive tried contact with them, they was happy to help this problem even It was not their fault ,,
You should contact with them again !
If you just follow installation well with You tube Video, It will not matter at all :)
cbbella
