Who stick with One UI Launcher?
Same here. Immediately installed square home.
I tried all of these but it's just not the same without the live tiles. I've just gone back to the stock launcher. Today I put my SIM in my Windows Phone and it just made me miss them all the more.
4 days. Not bad I guess...
Though, I tried something different than Nova Prime.
Evie Launcher
Amazing so far, includes Gestures out of the box unlike Nova that requires Prime.
Still sticking with One UI launcher, for Google home feed I have mapped the bixby single button to launch Google app. For now that work around is kind of acceptable for me.
When I get mine this will be the first time I've used anything other than Sense UI by HTC. I'm a little nervous about it because I really liked Sense. The workaround for the bixby button so that I can change it to Google Now I hope will help ease my transition.
I like it but I really don't like the app draw that I have to swipe left - right and they frame all the icon so I changed to pixel Launcher with Google feed on the left and I really like it better.
The phone is excellent anyway.
Link?
I am sticking with the OneUi on my S9+. So far it's above and beyond TouchWiz. It feels polished and modern. What I miss the most is customizing the dock, and having more than 1 page in the doc. Also notification counts for ALL apps.
I'm sticking with the One UI. I really like the edge panels. I wish it had double tap to turn off the screen (like with my LG G6).
Yes! With the power button out of reach on the S10+ that would be an EASY and impactful improvement.
You can use the edge panels with Nova... And set double tap to sleep on the home screen with it...I believe.
I might switch to Nova just to get google feed unless someone knows another way to get the feed.
Yeah switching to Nova or one of the Pixel launchers is a good option, but when I use One UI I have mapped the single press bixby key to bring up the Google app which is like a Google feed. So instead of swipe from home screen I press the bixby button. We got to put the useless bixby button to some use
Thanks for the tip. I'll try it out when my phone gets here.
I used the One UI launcher for a few days but ultimately decided to go back to Nova. Samsung definitely made very significant improvements to the One UI launcher but it's still light years behind Nova in what it will allow you to do. One very small example is that you can't switch icons to icon packs you have downloaded from the playstore and you can't change the folder labels from white.
If you're happy with One UI then all is well but if you're looking to really make the phone uniquely yours I'd recomend downloading the Nova launcher.
Abheetha Athukorala
