Why am I unable to answer or cancel incoming calls on my S7 Edge?
  • Start date Start date
A
AC Question
I cannot answer or cancel incoming calls on my s7 edge
My phone rings but screen doesn't change so I don't know who is calling nor can I answer or reject it. Have turned phone on and off and didn't work.
Re: I cannot answer or cancel incoming calls on my s7 edge
Does everything else work on your device? You can try entering recover mode, and wiping the cache partition, though its worth a shot, I think your problem lies elsewhere. let us know if cache clearing works.
chris
chris
Wow thank you Chris that worked once I worked out how to clear the cache.
We are so glad we were able to help you. Please don't hesitate to contact us again, we're here if you need us!
Chris
