Why does my Galaxy Note Edge say no memory card inserted when it is in?
  • Start date Start date
A
AC Question
My galaxy note edge says no memory card inserted when it is in
Phone just stopped reading sd card out of the blue, it is a galaxy note edge, and i am puzzled as to why!!!! What could the issue be????
Re: My galaxy note edge says no memory card inserted when it is in
I would suggest backing up the SD card to a computer or another storage device. Format the SD card and re-insert it; see if that fixes the problem. If it doesn't, then its either a damaged SD card or SD card slot. The only way to test is to re-insert a new card and see if that works. If not, it's a possibility that the device has damaged hardware.
If that's the case you can see if Samsung will assist with a repair/replacement if covered under warranty.
This is a bad SD card. Same thing happened to me with a SanDisk. SanDisk replaced it for me and all was right with the world again.
Definitely test with another SD card and see if it works. If it does then don't even try to use the card that gave you problems cause you might lose whatever ends up on it.
Sent from my Samsung GALAXY Note Edge on AT&T
Because microSD cards are the most unreliable things.
Tappin' and talkin' with Tapatalk.
mhuk01
