Why does my phone get hot and drain the battery fast on my S7 Edge?
  • Start date Start date
A
AC Question
Why does my phone get hot and drain battery fast s7 edge
After few weeks my s7 edge began to draw faster battery and get hot. I deleted resetted the phone. I turned power save mode on. Nfc of. Wifi off when screen closed etc... still i get too much battery drain. Screen on timeis mostly around 3 hours. It was not like this and I don't know what to do. Warranty is probably not going to accept it. Because they just don'twant to change it. I got picturs of phone heat and gsam battety drain
Re: Why does my phone get hot and drain battery fast s7 edge
Welcome to Android Central!
They don't want to change your phone? They are obligated to change your phone if you respected the warranty contract. Don't be afraid to get what it yours. Change your phone.
Best regards,Mikey. I hope you found what you were looking for.
Sent from my Samsung Galaxy S7 Edge SM-G935F.
Contact Samsung Claims department and file a claim. They will either attempt to fix your current device, but if they are unable to, you will receive a certified A quality refurbished device.
I am in a support convo with Vzw right now about this issue. Hope it gets resolved quickly. I'll try Samsung if they don't honor it
baharzaman
