Why does my wifi disconnect on power up?
Sammytheorangutan
158
Wifi disconnects on power up
EVERY time I power up my Edge, I have to reconnect to my home wifi router. With every other phone I've owned (with wifi), it would automatically connect on power up (assuming I was within range of the router). Once in a while, it will disconnect on it's own, too.
What's the fix for this?
Re: Wifi disconnects on power up
I had that with my samsung galaxy s5 and when this happened i reset the modenm of the wifi in house then it was solved but when i get to my work and come back and not going automaticly going on wifi
i had called the provider and they had written i must t=do the homewifi on a other channel and i did that and i had never had that problem again
i don,t say it is the same issue with your Phone
I would ask the provider first if it is coming truth the homewifi they can see that and if tehy say it isn,t the housewifi then it is your Phone and there is have no answer for that
jochu
