Why does Sense not do landscape?
Also the app "Home Switcher" will help you switch easily. Use System Panel app or such to kill the old one possibly.
I really like that icon bar in Launcher pro.
Do either of those launchers include clocks/alarms/timers/etc? I really like Sense's alarm app where you can easily flick to quickly advance the time when setting an alarm - so much better than stock Android. I use alarms a lot & would hate to lose that ease of use.
If you like Sense's alarm app, try "alarm clock plus v2" -- some guy beefed up the stock app and made it a lot better.
How do you deactivate sense?
go to settings then go to applications then go to manage applications and look for htc sense... tap htc sense and look for where it says "launch by default" and tap the clear defaults button.. then u should have "stock android" after a quick reboot...
Buka Blokir Mution Bank
