why hello there , new girl needs help w/ droid charge problems
kayhoe
5
heyyy , so ive never had a customize-able phone until just about 2 months ago so bare with me , ok my Samsung Droid Charge ( rooted ) was functioning normal until the New vzw "system update" notification was popping up and accidentally began installing , next thing i know my phone reboots and is sent into "Android System recovery <3e> (Samsung recovery Utils for BML) , ive rebooted the charge billions of times trying to reboot it to my "nandroid" settings by holding down the volume buttons and the home button when i power up the phone , managed to get that screen to appear once but returned to system recovery 3e and remains stuck this way .
ive been down the list of actions im given that is labeled as the following
-Reboot system now
-apply sdcard:update.zip
-wipe data/factory reset
-wipe cache partition
-format internal sd-card
i was hoping maybe one of the actions would reset the settings back to before the update was initiated but none of the actions did anything to get me past recovery mode .
the screen its self has the android symbol and a triangle with "!" inside and has yellow text over that reading exactly this :
--bootmode =7 from cmdline ...
( in red text --->) E: Cant mount /dev/block/mmcblk0p1 (invalid argument)
-- movi_check start..!!
checksum confirmation need_checksum [0]
Not need checksum confirmation
--Movi_check already executed !!...
--movi_checking done!...
#MANUAL MODE#
So my question is , what the hell can i do to move past this screen i dont care if i have to reset it completely and lose everything i just want it to be functioning like normal again
plzzz any suggestions will be appreciated im so out of my range of expertise here
jtb
