Why i can't select USB configuration? Android 9
  • Start date Start date
Status
Not open for further replies.
A
Android Central Question
Hi,
I have a leg v30 whit Android 9 and I can't select the USB configuration and when I click on it doesn't work.
Others aspect works well, I mean, drivers on the PC are updated, the cable woks in other devices, USB debugging is ON.
The only problem is when I try to click on USB configuration I can't select nothing.
I've seen issue online again and again. with lg phones and no one seems to have a solution. I have an LG Stylo 5 running Android 10 and have the same issue - when I click on Select USB Configuration the menu comes up and closes before I can choose an option. It's set on Charge and it's impossible to switch it to Transfer Files. I tried all of the above suggestions and nothing has worked. Very frustrating.
Welcome to Android Central! See response to your same question in this thread: https://forums.androidcentral.com/threads/android-file-transfer-not-working.1056601/
Reactions: Laura Knotek
Status
jenleasch12683
