Why is Cell Standby using the majority of my battery?
assmodius
4
Got a new 64 Gb Note 5 from Verizon yesterday and today it's been bleeding juice while locked.
Adding a screenshot of my battery usage.
Help?
Install gsam. It looks from the screen shot that you have a weak signal which could cause high cell drainage
Sent from my Verizon Samsung Galaxy Note 5
Help?
I haven't seen your screen shot but can tell you that nothing will work... I mean you can disable all you want... It won't work. As long as you have WiFi on... It will drain your battery. Hopefully Verizon will fix this... But for now you can disable all you want... Nothing will help.
Help?
I had the same thing happened on my Verizon note 5. I had to return it for a new one. Now it's not that high but still shows cell standby. A lot better.
Mod Note - Some posts have been cleaned. If you have nothing constructive to say please just move on.
Thanks.
I got the same phone from Verizon about 3 weeks ago and had similar issues at first. Note that the problem is on WIFI only. I am not sure why, but for some reason it seems to have diminished over time. Looking at it right now after being on WIFI in my house for about 6 hours, cell standby is at 3%. It used to hover around 25-30%. My cell signal at the moment is hovering between 2-3 bars. Your screenshot shows only 1 bar, so that could be the issue.
I tried disabling HD calling and that didn't make any difference so now I keep it on. You can't be on a call and use data at the same time if you don't have it enabled!
Another thing I did was follow the De-bloating thread on XDA forums. Installing Package Disabler Pro and disabling a bunch of bloat has increased batter life, and who knows, maybe helped with this standby as well.
I have advanced calling on all the time and it uses less than 1 percent of my battery.
how does one disable VoLTE on the Verizon Note 5?
Go to settings and Advanced Calling...turn that off. Verizon calls its VoLTE Advanced Calling. However, if you turn it off...you will only be able to be on call or use data...not both.
