Why is my battery charging so slow.?
  • Start date Start date
A
AC Question
why is my battery charging so slow..? draining fast too.!
I have a samsung galaxy tab 3 (3.4.0).. My battery takes about 6 hours to fully charge! if the tablet is "ON" while charging,,it will not charge,but instead lose charge!!!
Finally when my tablet fully charged, It will completely drain in under two hours!!!! please help me.[galaxy tab 3 (3.4.0) I think this is right]...Thanks
Re: why is my battery charging so slow..? draining fast too.!
I think you should be on at least android 4.3.x but are you using the factory charger and cable?
Have you tried a separate charger and usb cable?
When was the last time you checked for a software update?
I would at minimum wipe data cache via recovery mode. I would more so suggest a FDR if you feel up to it to boost the results the most.
Bride96
