Why is my battery drain so fast and heated fast?
  • Start date Start date
A
AC Question
why mu battery drain so fast and heated fast
my asus zenfone 5 battery drain so fast and heated fast and become hang i have used only for six month i have used it happen by version or too much app install
Re: why mu battery drain so fast and heated fast
Welcome to Android Central! Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
http://forums.androidcentral.com/am...ide-how-post-screenshots-android-central.html
What you're describing often ends up being a failing or defective battery, so you might have to look into getting it replaced.
slackingfred
