Why is my Nexus 5 Manual OTA Stuck?
Noah Wass
Nexus 5 Manual OTA Stuck!
Hey all -
I'm attempting to manually update from Android 4.4 to 5.0 and I'm stuck at one of the last steps. I was following the guide on AndroidCentral for manually updating your N5 and am on the step of typing 'adb sideload OTA file.zip' into Terminal (I'm on Linux Ubuntu).
When I type 'adb sideload OTA file.zip' (obviously using a shortened filename here), I get an error in Terminal that says * cannot read 'sideload' *.
What now?
{update} I've checked that the ZIP file is in the same directory as ADB. It is. I'm now downloading a new update file to make sure that the first wasn't corrupted.
Re: Nexus 5 Manual OTA Stuck!
You certain the zip file is in the same directory as the adb? If not are you referencing the correct directory? Error sounds like the file doesn't exist where you're specifying
Have the same problem !!! Says cannot read ota file.zip and i have it in the same directory as well. Dont know what do
Check to see that the size of your zip file matches the correct size. The correct file size is 502,777,5160 bytes; size on disk is 502,779,904.
Yep, correct size and everything. Really have no idea what could be wrong but it seems like more people have this problem ( find a few of the same comment under videos on youtube).
To be honest I found AC's tutorial a little strange. I used an online video tutorial by some guy who goes by raybansandfedora on YouTube .
From [INFO] Nexus 5 OTA Help-Desk | Google Nexus 5 | XDA Forums
1) Download the OTA.zip on your PC, rename the file update.zip, then place file in the same directory as adb.
2) Make sure you have USB Debugging checking in the Developer Options, then connect your phone.
3) Open the command prompt from the directory above on your PC and type the command: 'adb reboot recovery'
4) When in recovery, you’ll see an android laying down. Press volume up and release. The menu will appear. Select “apply update from adb”
5) Using the command prompt type: 'adb sideload update.zip' The file will load and the update will begin.
6) When completed, select reboot.
Can you confirm that you are doing all these steps in the right sequence?
Same problem for me. Troubleshooting issue in thread "I got lollipop and here's how to do it." All the suggestions checked and re-checked, still getting cannot read error when at adb sideload step.
Noah Wass:
Are you using a MAC? I read another post here where several MAC users have encountered the same problem using the Safari browser to do the download. But one said he tried IE11 and that one worked OK. I have no idea why this should matter, but apparently it does.
Checked everything. The only thing i am not sure about is the directory. I have both update.zip and adb (3 files) in C/android/adt bundle../sdk/platfrom tools.
Everything else is checked and I have no idea what could be the problem.
update : So I just got the OTA update but this issue still seems unsolved (for many people). Guess we will never find out.
Equatorial
