Why is my note7's battery draining
  • Start date Start date
A
AC Question
So I bought a post recall model note 7 about a week ago, and I'm having a problem. My battery will drain about 4% an hour, in my pocket with things like always on display turned off. I came from an iPhone 6s that had great standby time. Is this normal for my note7?
No is not normal, my Note 5 drains only 3% over night when I'm not using it.
When I was having battery problems I noticed that Skype app was battery hungry, even when I force stop it still returns, and I was losing 5 % hour. I deleted it and now it's all good. You can check in settings- battery what is draining battery the most and in developer options running services . Also in application manager every app shows if it used battery. Some games might drain some battery, because they are running in background. Let me know what you found. :)
brianatem32
