Why is my phone getting hot when I clear RAM?
Yes i deleted the app and now feel the difference
But what about the smell of screen when it gets heat? Do you have it too if u close your screen when he is hot and smell him?
if you can smell the screen turn the phone off and let it cool down. Don't keep using it when it hot and you smell heat.
Now its ok i dont smell it since i removed this app..but i ask if its ussually haappening? If its ok or not.smell like something hot kind of burning cause hot..all i ask if u can smell it if u get close the screen when heat high
usually shouldn't smell it unless its overheating a lot if you're using the phone alot and playing a large game or something it may happen
Really dont know ehat to say..im using phone a lot but not all time play..u kbow internet and staff..no game only
Very wierd situation and i have change the screen one time in the company...
You see, my friend, the RAM is not the only thing temporarily storing tasks here. The CPU has it's own cache reservoir as well which is the primary co-pilot to the CPU...long explanation short, this cache is supposed to transfer instructions to the CPU but is having great difficulty doing so, because unlike Windows, Android will keep tasks inside this cache for quick opening which unfortunately causes overheating easily. To get to the Task Manager and remove all of these unnecessary tasks, you can hold down the Home button from any screen of your phone and you should see a list of programs such as Facebook, YouTube, etc. which is the list of programs you have opened since you last turned the phone on. (If you don't have an S4, it may or may not be different...most times holding Home does work though.) Look at the bottom right corner of the screen and you should see an icon that looks like a trash can in front of some horizontal bars. This will clear all of the tasks currently inside this list and will help your CPU immensely. The Task Manager is a great multitasking tool as well...you can google "How to use Android Task Manager" for more information.
I think the simple solution is to uninstall Clean Master. The S5 doesn't need it. Use the default feature on the S5. 😒
witnessloc10
