Why is my Samsung Galaxy S4 battery draining so fast?
Link169
19
Samsung galaxy s4 battery life
my battery quickly drains with literal use. Plenty of people say "check battery settings to find whats killing it" usually says screen but i know my screen, at the lowest settings, should not drain 10% in 16 minutes with it being off in the 16 minutes. I recently got a new battery, reset plenty of times, gsam battery monitor says on average i get 7hrs a day and thats just music playing between classes and off during class, not off off just not used.
any tips to find out the true source?
here's screenshots of said performance
Re: Samsung galaxy s4 battery life
Welcome to Android Central! It would be more helpful to see the stats after the battery has been used from a full 100% charge down to about 20-30%, so we get a better picture of the overall use.
Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
Here's the screen shot hope I did it correctly
