Why is my Verizon Note Edge Bluetooth Buzzing/Crackling?
ofosho305
12
I just got a Verizon Note Edge and music sounds great over the 3.5mm jack, however over Bluetooth the audio has a noticeable crackling/buzzing sound on higher pitch tones. I am connecting it to a Lexus ES 350 2013. Could this be a hardware issue that I should exchange the phone over? Is anyone else experiencing this?
Re: Verizon Note Edge Bluetooth Buzzing/Crackling
It could be an issue with the phone or with the Lexus audio system's Bluetooth. You'll have to localize it (use a different car, use a different phone, see where the problem follows).
l used a Moto X and it worked fine. I did notice that the Note Edge made some more controls available, repeat and random, so it must be a different bluetooth version. I'll try with another car when I get a chance. Could it be a bluetooth version issue? Anyone know why I get more controls?
Yep, happens to me on my Cadillac. I thought was my vehicle's bluetooth connection because the hiss/buzzing sound occur with both the note 4 and the edge. Yet I get a incredible sound through 3.5 jack. I know it's suppose to be better, but this bluetooth hiss is not normal. I'm going to try another source (other than my phone) tomorrow.
Let me know how it goes stronggeek. I went to the store and had the same hiss/buzz/crackle with the Beats headphones over bluetooth. It went away when I plugged the phone into the same headphones over 3.5mm. So I paired the demo Edge at the store to the headphones and that sounded fine. I just got the Edge, so I am exchanging it for a new one. Hopefully it is just a matter of replacing this one.
I have the same problem with my LG HBS750 headset. I thought it was just me though.
I have the same headset and use it all day at work to listen to podcasts. Not noticing any of that.
I found out that it was my Moto 360 that was causing the issue. When I disconnect it, Bluetooth works fine.
Similar problem here. I've got a Honda Civic and got no noise, however my bluetooth connection drops every 5 to 10 min consistently. From Tunein, Pandora or whatever I'm streaming.
If I restart the phone, it stops for a while and at some point, will do it again. Unfortunately I can't identify a pattern as of yet.
Contacted Samsung who BS'ed me saying to uninstall apps I don't use. When I said it was BS then she asked to try on a different device (which I would have, if I only had one easily available...) - however the car doesn't do that with my wife's S5.....
Nehasingh12
