why is screen using so much battery :/
Deanig_12
372
Hi all i cant go 6-7 hours without charging my phone i have got an s2 running 4.1.2 my brighness is turned right down andni cant seem to find the problem :|
I have my screen all the way up. I get about a day an a half with my battery. (GS4)
Maybe i need a new battery if so how long do i charge the new 1 for??
You only need to charge it to 100. Contrary to popular belief, there is no need to calibrate your battery. Trust me I'm a software developer.
Sprint GS3 Running TN's Msg and Chubbs
Ok i dont get you what do you mean callabrate :s and i dunno if its the battery or not but whenni click on battery in settings its says screen 65% and i dunno what is cause this issue
Hey, I had an S2 myself, and it also has really bad battery life. I think the problem is that the battery is getting old. After a certain number of discharge cycles, the amount of charge the phone will hold changes drastically. I bought a new battery, and now the battery life is a lot better.
cmdouna
