Why isn't my Whatsapp LED light working on my LG G4?
A
AC Question
whatsapp LED lights not working lg g4
when i get a msg on whatsapp the LED light is not flashing at all.
all the setting on whatsapp and on the device setting are on and it should work.
i use IG G4, android 5.1, V10b
redlinecoatings
184
Re: whatsapp LED lights not working lg g4
On your phone settings is only the notification led on with it checked off for downloaded apps only? If not they could be conflicting. I use led blinker personally and it works flawlessly.
Ravit B
10
"downloaded apps" was off!!! it works now, thanks!!!!! :))))
Edit - now i have a different problem - the LED wont stop flashing even after i read the msg..
redlinecoatings
184
Have you tried led blinker for your notification lights? I use it and it works flawlessly.
Sent from my Nexus 6 using Tapatalk
JT1981
