Why isn't the sound on my Razor Max working?
  • Start date Start date
A
AC Question
no sound from razor maxx
I do not have any sounds coming from the phone (ring tone etc.).. I did a system restore and it did not fix it.. the settings have the sound activated, and the volume level is all the way up..any suggestions??
Re: no sound from razor maxx
Welcome to Android Central! When you go to Settings>Sound, select Ringtone and tap various ringtones--do you hear the sample sound? I recall that sometimes the sound would cut out on my old Razr Maxx, and testing out various ringtones would "wake up" the speaker again.
If that doesn't work, and absolutely no sounds come from the main speaker, then it may have failed. Does the earpiece speaker work normally on calls?
tanamorgan
