Why isn't there an option for the Note 5 64gb on Verizon?
Re: Note 5 64gb (verizon)
Oh that is bad.. I'm glad I never went with Verizon.
Why is that a surprise? VZW is CDMA, AT&T and Tmobile are GSM. So, you have to buy a phone with a CDMA radio in it to get it to work on VZW's network. Phones made specifically for AT&T's networks won't work, although phones that are made to work across networks (like the Nexus 6 and iPhones) will do fine.
Personally, I couldn't care less about color because I always have a case on my phone (not that I don't like the black anyway). I though about the white phone just because it would not show fingerprints to the same extent, but its not like I ever use the phone without a case anyway.
I'm way more annoyed that a 128 gb version is not available, which I find perplexing. I don't personally NEED that much storage but I probably would have opted for it just to be on the safe side.
Best Buy has them listed for other carriers. Seems to me that Verizon isn't even selling them at all or back ordering.
You are correct. The information I gathered was that Verizon opted out of the white 64GB model. It was never offered though in the pre-release days there was for a short time a place-marker page on the Verizon website.
or one of these microSD card readers that is small enough to leave plugged into the phone and doesn't require the OTG cable portion at all.
http://www.amazon.com/dp/B00R0ZAMTM...ag=hawk-future-20&ascsubtag=UUacUvbUpU4819251
or this 64GB flash drives in a USB & microUSB plug also small enough to have plugged in while you use the phone.
http://www.amazon.com/gp/product/B0...ag=hawk-future-20&ascsubtag=UUacUvbUpU4819251
http://www.amazon.com/dp/B00R0ZAMTM...ag=hawk-future-20&ascsubtag=UUacUvbUpU4820017
http://www.amazon.com/gp/product/B0...ag=hawk-future-20&ascsubtag=UUacUvbUpU4820017
Yeah, sorry but that's not small enough to leave connected while you use the phone practically
aravrajak
