Why S8 Plus rear camera going blurry
martin mcgillivray
This is how you get rid of the blurry put it put your camera on rear camera give it a shake and it should be clear just done it myself pic is fine
Welcome to Android Central! Thanks for the tip! Although it shouldn't be doing that. It makes me wonder if the autofocus mechanism in your phone's camera is faulty, and getting stuck from time to time.
In having the opposite issue. My rear camera is clear, but my front one is all off a sudden not clear.
The first pic is my front camera.
Do you have a screen protector, or some other cover on your phone?
I have a screen protector but I took it off because that's initially what I thought the issue was. Those pictures are with the screen protector off.
Ok. It doesn't so much look blurry as it looks like there is a film over the lens.
Here's a thought, it's possible that you have condensation. That can happen if you enter a cold relatively dry area from a warmer humid area. It can even happen in water resistant devices. The phone is water resistant, but not air resistant. Small amounts of water vapor can still enter the phone with the air. I've had it happen to my camera lenses.
Js42FL
