Wi-Fi and LTE on at same time on s7
Evolowe
Hey. It took me two hours of going through every settings and every app to determine the root of the problem. I'm aware of the trouble shooting sets in other post like: In developer mode making sure Always Keep Mobile Data on is toggled off. Make sure download booster is off. Under advance Wi-Fi setting make sure Smart Switch is toggled off.
If you have done the above steps and you still have both Wi-Fi and LTE showing go to Device Maintenance, select Memory, then Select view all. Once you do that deselect all applications and select one at a time and press the Clean Now option. Repeat each step one by one selecting clean now with each one. Do this by waiting a few seconds after you select each app and wait to see if the LTE icon disappear.
Once you have determined the app that was causing the issues (In my case The Alexa app by Amazon) was the culprit. Either go into App setting and disable Mobile Data running in the background or delete the App.
I normally don't post to forum's but I had to share this because I did not find a site that resolved the issue.
To be honest... you kind of wasted your time. Both being active doesn't matter at all. If WiFi is showing it uses WiFi. It just has LTE ready for immediate fallback. This is a common thing among new phones :P.
This issue just started a few days ago. I've had my phone over two years and it had never showed both at the same time. I'm not sure about never phones but with my phone it's not normal. So you may not find this useful but it's clear a lot of people will. Just do a search and you will find post and videos on people trying to resolve thus issue. Have a nice day.
Thanks OP. A year later your post was incredibly helpful as I had the same issue and it is quite the annoyance when my notification bar has an extra unnecessary icon clogging things up. FAR from a waste of time.
This has been on my my Samsung 8+,9+,Note9,s10+ still have all the phones to this date ,stays on for awhile goes back off must be something using data for the moment while on wifi , but never bother tracking it down .
mannanqureshi
