Wi-Fi Issues? Please HELP!
Rune Arc
Active member
Oct 11, 2012
33
So I factory reset my phone and
before that the wifi was working fine,
but now,
for some reason i get this loop of
"Obtaining IP Address",
"Disconnected",
then does it again.
Anyone have any ideas?
Will thank <3
Example. It Loads this then disconnects after a while and repeats.
Try rebooting router and go into WiFi settings on phone and forget the WiFi connection, reboot and try setting up again.
Are you stock?
Sent from my One V using Tapatalk 2
Are you stock?
It's not rooted, it was though, but even then I did't do any roms or anything. and i's not just my house wii, its any wifi for some reason.
Hold the wifi thong name and then chose "forget" or something like that then try it again and see if it connects
Sent from my LG-LS840 using Tapatalk 2
RichardDixon
