Wi-Fi issues
Starting yesterday my wi fi is shutting out.. let me explain... I connect to a couple diff networks thruout the day, when I get back into a WiFi zone and try to connect the WiFi indicator turns off and on multiple times.. I have to end up forgetting the network (twice because it will turn off and on again) and manually connect.. what gives?
Sent from my HTC6435LVW using Android Central Forums
Check the widfi setting for BAND, ensure it's set to auto I've seen issues with wifi toggling when a single band is selected.
So i was messing with my home network the other day and took the band off auto on my DNA and completely forgot, it's now back on. TYVM for the fix!
Try an app called Best Wifi Keeper Pro, it fixed the problem on my Thunderbolt and I run it on my DNA prophylactically with no problems. It costs a buck.
Sent from my HTC6435LVW using Tapatalk 2
I actually had it for a while, but found it reconnected to wifi slower than phone does on own and uninstalled it. Thanks for suggestion though.
cinemacritic
