Widget time
  • Start date Start date
I'm still waiting for this problem to update itself as well. I've tried everything and took it in to the AT&T store and they said to wait!!??! Frustrating
Samsung Weather Widget
Go into App Info - Storage: Clear date and cache - It will delete your current location, but just add it back. The time will be correct and will remain.
Weather app For all S8+ and S8 users. if you clock did not update to Daylight Savings this is how you correct it. Got to your setting
Apps
Weather
Force stop
Clear catch in the memory
Then go to your city
App should of update to new time.
It just worked for me. Hope this helps all of you. Best of luck.
Worked!!!!
Re: Galaxy S8 clock on main screen not updating to DST
The lock screen and upper righthand corner clocks/time automatically updated to DST, but main screen clock did not. I double checked automatic update, restarted 2 times. Nothing will make the main screen time update. It appears to be connected to a weather channel app, but not seeing this in my apps. The weather clock is correct.
I removed the widget from me home screen, then added it again. Solved it for me.
I FIXED THE ISSUE. Go to settings>>weather settings>>show on widget>>change to current city only. You can change it back to all added cities if needed and the time will still be updated.
This is the fix that worked for me. Tried the delete data and cache but fix only lasted until I added back my locations
RESOLVED. Go to settings> General Management> Date & Time> Automatic Date and time turn Off then back On. If it doesn't work, clear cache as suggested above and repeat date and time on/off.
I had same problem but today it's showing right time.
I had same problem with my S9+
.. widget on front (home) screen showed correct location but wrong time (off by 2 hours). I opened widget and it showed correct time ... ??? ... so i went to Widget Settings turned Off Current Location. Turned Phone GPS (location) on. Went back to Settings turned Current Location ON and Viola!! the front screen widget shows Correct time
Last night mine suddenly went 4 hours ahead. Galaxy S9+. Did the force stop, clear cache and data, hoping that fixes it. Most annoying!!
Try changing the settings for your battery management: Settings-Device Management-Battery-change Power Saving Mode to OFF.
Winnie
