joshua.worth Android Guru Mar 24, 2010 608 45 0 Feb 8, 2011 #1 It seems anytime I have Bluetooth connected I have no wifi connection no matter how close I am to the router
E eggFuJON Well-known member Sep 8, 2010 105 1 0 Feb 8, 2011 #2 Are you rooted? Try resetting the router. I'm sure both BT and WiFi would work at the same time.
I idbl_fanatic Well-known member Jan 30, 2011 171 16 0 Feb 8, 2011 #3 eggFuJON said: Are you rooted? Try resetting the router. I'm sure both BT and WiFi would work at the same time. Click to expand... Yup, just tested it, works fine`
joshua.worth Android Guru Mar 24, 2010 608 45 0 Feb 9, 2011 #4 Doesn't work for me never rooted an android before
joshua.worth Android Guru Mar 24, 2010 608 45 0 Feb 9, 2011 #5 It works a few minutes then wifi says out of range (this is in call)
