Wifi authentication problem
Jul 30, 2016
After rooting, Playstore didn't worked properly and in one turorial stood that changing Ip adress may helps. So i went to advanced settings, changed DHCP to static and then, what probaly sounds stupid, i also changed my IP adress to the same as the one shown in the tutorial picture. Since then i get authenfications problems the whole time.
I've switched back to DHCP, restarted my phone and router and even formated my phone because i thought it would fix this. Apparently i still have authenfications problems
How you see i'm a noob at this and haven't really found a solution through googling. How can i fix this? Thanks for all answers
(I have Google Nexus 5x)
Welcome to Android Central! Moved to the N5X Rooting forum.
Have you already tried rebooting your router? Are you unable to connect to any wi-fi network, or is it only your home network?
nic12345
