WiFi Calling - constant notification
ive had this setting pop up on me since the S9 and also now on my s21+. But i dont remember what i did because it doesnt show up anymore. Try switching from wifi preferred to cellular preferred for wifi calling preference. You could also try turning off wifi power saving in the wifi setting.
Sidenote I dont have the wifi calling app in ALL app settings like you guys do. I just have a setting with 2 options. network preference and e911 address. Im on Tmobile
Well, I've finally come to the conclusion that this message is by design - it's not a bug. My friend, who has an S21 Ultra, was recently over at my place and he got the message, too (he had never seen it before coming over to my place), which tells me it's my router, possibly not putting out a strong enough signal/connection (?). Not sure exactly, but the only logical conclusion is that it's an issue with my router just not being robust enough, which is triggering that notification.
It's possible your wifi , can try on another wifi to verify.
Galaxy S21 ... Unlocked using T-Mobile
Is anyone else getting this way-too-frequent notification?
There's a similar thread about this here in the forum, but doesn't look like there was any resolution.
There's gotta be a way to stop this notification without actually turning off WiFi Calling.
I did too on my Note 21 Ultra, US unlocked using tmobile. But then I just bought a S21 Ultra Tmobile branded one and it does it once in awhile too.
Ashok Dharshan
