Wifi calling help please
  • Start date Start date
A
AC Question
I am currently using an s6 and after installing the latest software update I have lost wifi calling...........all online advice us to go into settings-applications and the phone icon however the update has change the menu and the phone icon is no longer in apps.
Also if I open the phone icon and try the settings in the top right the enable wifi calling option is no longer there. If it makes a difference I am using Vodafone in the UK. Any advice appreciated.
Assuming that the carriers in the UK are like the ones in the USA, they have their hands in the code prior to you getting the update. That gives them the option to add, or in this case remove, features as they choose.
Contact your carrier to see if this is what happened.
FahadsTech
