WiFi Connection issue
android jack
244
I have been using WiFi without problems other than signal strength. Recently, however, I see that my phone a some point disconnects from my WiFi. So I check and i see that the WiFi spot (my router) is there but it won't connect. I turn WiFi off and on and it connects, but very soon after disconnects and same thing, WiFi spot is there but won't connect. The only solution I have is a restart of my phone. Is there anyone experiencing this issue and have another solution?
Make sure the back to your phone is snapped in all the way, htc had a brilliant idea of sticking the antenna in the cover
Sent from my ADR6425LVW using Android Central Forums
I see you posted this at 3am... is this when the problems occur (overnight) or during the day as well? The Rezound has a special "sleep" mode at night that turns off WiFi from like midnight until 7am, or something like that.
if you have the newest update (ICS) there is a advanced setting to maybe try>>> >Menu>settings>wifi>menu>advanced>"best wifi performance/may consume more power"
The time I posted this has nothing to do the time this happens
I may have been proven wrong, the time is around the same time since it happened again
The same thing was happening to me. Under wi-fi advanced there is a setting to "Keep Wi-Fi on during sleep". I changed that to always and the issue doesn't happen anymore.
bantuanfintech
