WiFi Connection Problem on Specific Spot
rax369
5
Hi there,
I'm having a rare WiFi connection problem when trying to get connected to an specific wireless router. On this router other devices like smartphones, and laptops can establish connection w/out problem. The issue is specific on my cell.
The same cell gets connected to any other WiFi spot I try to connect.
What I have tried so far?
* Deleting that SSID, then adding it againg to the wifi networks
* Powering off the phone, and removing that battery for around 15 min (have read it sweeps dns cache)
* Wireless router already rebooted
I also tried to install some apps to locate the issue:
* Using "Fing" it helped to make some pings and traceroutes to some public sites (so is not a connectivity issue)
* Also tried "WiFi Fixer" didn't help @ all, actually it didn't find any problem
What apparently is happening is that URLs are not being resolved by the DNS servers (they are reachable already tried that) but not resolved. :-\
My phone specs:
Model: SGS2 International (GT-i9100)
Android: 4.0.4
Any ideas on how to solve this annoying issue ??? :'(
I am having the exact same problem after upgrading software. Current Android version on my LG phone is 4.1.2. Just tried reset to factory data but the problem still remains. Any solution?
rosemar3
