Wifi problem after gingerbread update ...
gill.batez
23
Hi,
I am not able to connect to Wifi after i completed gingerbread update. When i go to Wireless networks, and turn it on, it says turning on wifi, and after some time the message goes to turning off wifi, and then it turns of the wifi. So it just turns off, the scan also does not detect any network. Please guide/ suggest how should i make wifi work on my atrix.
Thanks
Go to Settings/Battery & Data Manager/Data Delivery and make sure that Background data and data enable are checked.
Thanks for reply, Both the options are already checked..
Well Restarting the phone solved the problem, now i am able to find and connect to wifi networks.
slametmunawir010796
